Forums >> Revit Building >> Technical Support >> Method for makding Drawing templates
Fri, Mar 28, 2014 at 9:23:27 AM | Method for makding Drawing templates
SteveB
3.5 Stars: 5 Votes
At the end of a project that has all the families, sheets, etc loaded, I want that to become a template.  Right now I do this by combing through every sheet and manually deleting all drawing ojects, families, text, lines, detail items, etc etc.   Pretty cumbersome.  Is there a better way?   A third party add-in that makes the creation of templates from a revit project better?
I serached revit city arhives, my Lynda.com and cadclips for tutorials, as well as the Revit help, no luck.    Seems like an important tool to develop.
Fri, Mar 28, 2014 at 9:35:05 AM | Method for makding Drawing templates
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I'm not following what you want.. you want a different template for every job that you do?  You would create a template that has everything that you need in it and create your project from that.
Fri, Mar 28, 2014 at 10:02:53 AM | Method for makding Drawing templates
Read this HELP Topic:
Transferring Project Standards
Fri, Mar 28, 2014 at 10:34:05 AM | Method for makding Drawing templates
SteveB
3.5 Stars: 5 Votes
Teafoe5, no I want to periodically update the template.  With all the new things that may have been added to the last project. I will search "transferring project standards"
Sat, Mar 29, 2014 at 10:31:29 AM | Method for makding Drawing templates
SteveB
3.5 Stars: 5 Votes
its not about transferring project standards.   We would like to have legends, typical blocks for the project type, views, schedules, sheets pre loaded.  This sounds like a process that would strip out all drawing objects, text, lines, symbols from drawing views and leave sheets, project's fmailies, groups, schedules, etc in place.
Has anyone seen an article for typical method to start a standard drawing set with all of these standards in place?
Sat, Mar 29, 2014 at 4:41:14 PM | Method for makding Drawing templates
akaAlso
I'm just looking to get back on board with Revit after a very long break and collecting lots of links in my bookmarks that I have to get organised and review. Is there a better guide than this one from Aaron Maller? http://malleristicrevitation.blogspot.co.uk/2011/03/creating-revit-template.html
Drawing templates
Thu, Jun 10, 2004 at 1:41:36 PM
Revit templates
Mon, Jun 28, 2004 at 6:49:33 AM
templates
Wed, May 14, 2008 at 10:11:59 AM
Where have my templates gone in 2012
Sat, Apr 7, 2012 at 9:09:06 AM
Family Templates
Tue, Nov 26, 2013 at 9:56:21 AM
Page generation time: 0.2301
