Forums >> Revit Building >> Technical Support >> mass inside family
Fri, Mar 28, 2014 at 8:40:09 AM | mass inside family
solidsnakeala
using revit 2014,
**please check the attached images
 I needed to create some families that kind of organic shaped and that was impossible with the tools of the family like extrude, sweep, revolve ....
so is there any way to use the technique of mass modeling inside a family... or any other solutions  ???
thanks
Fri, Mar 28, 2014 at 8:55:07 AM | mass inside family
Revit does not do well with "soft" forms.  If you an do these in another program, you will be better off.
Rotating a mass in family
Fri, Aug 11, 2006 at 2:11:14 PM
HELP - Copying groups around ... causes mass objects inside to copy elsewhere?!
Sat, Jan 20, 2007 at 4:58:06 AM
adding mass in family editor or in place family creation
Thu, Nov 23, 2006 at 9:52:52 AM
Conceptual mass + family?
Fri, Oct 19, 2012 at 4:00:36 AM
Sawtooth Mass wont adjust
Sun, Jul 3, 2011 at 6:59:54 AM
Page generation time: 1.5974
