Forums >> General Discussion >> Wishlist >> Modify the View Range Settings
Thu, Mar 27, 2014 at 4:36:57 PM | Modify the View Range Settings
dpijon
I really wish that Revit would adapt their plan View Range settings, to include an option for View Height, similar to "View Depth", only for items above the "Primary Range".
They already do this for items below, putting them in the <Beyond> line style.  It seems like it would be a very simple thing to add the "View Height" and put those items on the <Overhead> style.
My office show a large amount of canopies and overhead items in plan, as dashed lines, and it completely undermines the whole connectivity of Revit to use detail lines for this, because then you have to go back and constantly fix them any time something changes.
Fri, Mar 28, 2014 at 7:12:24 AM | Modify the View Range Settings
Please read this topic in your HELP:
Changing Line Styles for a View Underlay
Fri, Mar 28, 2014 at 8:42:50 PM | Modify the View Range Settings
dpijon
What I desire is a function where you don't have to trace anything, similar to how you can set it for things below the primary range.  I use the tracing method now, and I just think it could be streamlined into an automated feature.
View Range Revit 2014
Fri, Feb 20, 2015 at 9:55:04 AM
View Range or Cut Plane Settings for Split level and Cape style
Fri, Jul 6, 2012 at 8:19:54 AM
view range not right
Thu, Mar 4, 2010 at 1:08:41 PM
Modify Space Type settings
Fri, Mar 20, 2009 at 6:25:48 PM
View Range
Fri, Mar 13, 2009 at 5:05:41 AM
Page generation time: 0.6531
