Forums >> Revit Building >> Technical Support >> first time using gross building area - whouldnt my shafts be deducted?
Wed, Mar 26, 2014 at 1:08:39 PM | first time using gross building area - whouldnt my shafts be deducted?
oompal
hi, i'm just beginning a gross building analysis and I have many voids in my building-  some are double-triple height occupant spaces some are mechanical shafts. In any case I thought there might be a trick to getting my gross calculation to excluide these from its summary - is there?
Wed, Mar 26, 2014 at 1:39:28 PM | first time using gross building area - whouldnt my shafts be deducted?
So many questions....
  1. Are you using Rooms?
  2. or are you using Areas - Area Plans?
  3. If using rooms, how did you create the holes?
  4. Did you add room seperation lines around the hole?
  5. On area plans, did you sketch them and add the holes?
Floor Areas and Shaft Areas
Sun, Jul 27, 2008 at 10:39:38 AM
Rentable vs Gross area, gross area in practice
Tue, Mar 13, 2012 at 11:15:27 AM
Gross volume of a building
Wed, Jun 4, 2008 at 1:41:10 AM
Gross areas & Phasing
Mon, Feb 23, 2015 at 9:14:01 AM
Gross Building Area Tag
Tue, Feb 2, 2010 at 12:06:25 AM
Page generation time: 2.3983
