23 Users Online (21 Members):
Forums >> Revit Building >> Technical Support >> Floor finish schedule - Revit 2014
0 Posts No Rating |
I am currently modelling a building with multiple floor finishes in some of the rooms.
I would like to make a schedule with the following rows:
- Area
- Type code
- Room
- Description
- (Phase)
- Cost
- Notes
I have tried to do it by material takeoff, room and multi-categori schedule, but didn't get it quite right.
What is the best/easiest way to do this?
Because walls and floors typically span larger areas than simple rooms, they have not yet come up with a way to do this. Yes, you can split surfaces and assign different materials and schedule those but you will not have a location like a room. The solution is the old standard dumb room schedule. The room name/number/area is all model based but the finishes are added manually to the room schedule. As such, you will not be able to get material surface areas.
Room Finish Schedule by floor |
Wed, Jun 20, 2007 at 8:55:28 AM
Finish Schedule |
Mon, Aug 10, 2009 at 6:25:50 AM
Schedule material mark in door schedule - Revit 2014 |
Fri, Jan 19, 2018 at 2:57:03 PM
Finish Schedule |
Wed, May 21, 2014 at 2:27:36 PM
Population room schedule with floor finish |
Fri, May 7, 2010 at 9:28:13 AM
