Forums >> General Discussion >> Revit Project Management >> How well is revit prepared for technical drawings?
Sat, Mar 22, 2014 at 12:13:55 PM | How well is revit prepared for technical drawings?
archigrafix
5 Stars: 4 Votes
I wonder if anybody has experienced with a client or contractor problems with incorrect linestyles on drawings produced in Revit. Many of the clients we work in Scandinavia, large institutions, require that we follow National Standards regarding linestyles. Those are are national/european versions of international standards ISO.
I've noticed that revit does not allow dots or gaps less than 0.52mm. That implies that the majority of lines on small thicknesses are incorrectly represented in Revit. For instance, the axis lines (dashed dotted), cannot be drawn according ISO 128:20 on 0.13mm thickness.
Any thoughts or ways to solve this problem?
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
Mon, Mar 24, 2014 at 10:27:09 AM | How well is revit prepared for technical drawings?
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Interesting. That's a question for Autodesk and or your reseller.
Do we need to revamp technical forum?
Wed, Sep 22, 2004 at 3:06:24 PM
Stage Trusses ( technical name?) for awning support in Revit 2013
Mon, Nov 18, 2013 at 7:57:26 AM
Using Revit Structure to produce Steel Fabrication Drawings (shop drawings)
Sun, Feb 24, 2013 at 1:00:00 PM
How do I convert Revit drawings to AutoCAD drawings???
Fri, Sep 23, 2011 at 2:19:27 PM
how to prepare two different drawings of one level.
Sat, Nov 23, 2013 at 3:42:08 AM
Page generation time: 2.0018
