Forums >> Revit Building >> Tips & Tricks >> 3D Multi-planar Spline Sweep with Adaptive Family
Fri, Mar 21, 2014 at 3:23:47 PM | 3D Multi-planar Spline Sweep with Adaptive Family
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Adaptive Families ROCK ! See image below. Just:
Create a new family from the template > Generic Model Adaptive.
Add 7-8 points in sequential order and then make them 'adaptive'.
Creat a 'spline through points' and pick all the point in the same order.
Draw a small circle at the first point perpendicular to the spline direction.
Select the circle and the spline and click Create Form.
Save and load into project. Pick the 7 points in the correct flow / order.
Tab to grab the points and use the 3d controls to push and pull the points around and the spline will adapt.
You may want to do this from various flat / perpendicular 3d views.
Adaptive component multi-profile sweep (R13)
Thu, Sep 25, 2014 at 2:03:25 AM
sweep on spline in different planes
Mon, May 7, 2012 at 3:39:43 PM
Multi planar Rebar shape
Wed, Jun 12, 2013 at 4:43:44 AM
Revit 2010 Spline restriction
Mon, Jul 13, 2009 at 8:49:27 AM
spline with two heights?
Tue, May 12, 2015 at 8:08:32 AM
Page generation time: 1.6465
