30 Users Online (28 Members):
Forums >> Revit Building >> Technical Support >> Perspectives printing all grayed out!!!
Hi everyone,
I am having a big problem for a while. I have been printing several plans with different settings but no luck. They all turned out gray. This happens when I have perspectives on the sheet but only when they have shadows. When I turned shadows off. It just prints fine. Any ideas of what might be the causing it.
Thanks for your replies!!!
First, if a view is active on the sheet, the sheet will slightly ghost. Is that your problem?
Otherwise:
- Have you got the latest print drivers installed?
- Have you got all of the updates for your Revit? 2014 - 2 updates, 2013 - 3 updates
- Have you ever clead out your machine's temp files? CCleaner works best.
- Does your machine have enough memory?
No, it is not.
- Have you got the latest print drivers installed? No. I will.
- Have you got all of the updates for your Revit? 2014 - 2 updates, 2013 - 3 updates No. I will
- Have you ever clead out your machine's temp files? CCleaner works best. Yes.
- Does your machine have enough memory? It has 8 gb of ram and my files are not saved in the main drive. They are saved in a different location.
Thanks I will check that right away.
I did all that and I restarted computer. I am still having the same problem.
Thanks
Perspectives not printing properly |
Sun, Jan 22, 2006 at 10:22:48 PM
Distorted Perspectives |
Sun, Dec 31, 2017 at 5:07:34 PM
Two Point Section Perspectives |
Fri, Feb 24, 2017 at 8:19:15 AM
Switch ID Grayed out in Revit MEP |
Tue, Feb 26, 2013 at 11:33:36 AM
Render button grayed out |
Sat, Jun 30, 2012 at 2:16:34 PM
