24 Users Online (22 Members):
Forums >> Revit Building >> Technical Support >> Reloading Link's
4 Posts No Rating |
Hi everyone,
I am using 2014 and i am having this problems every time i reload my structural model link. It deletes dimensions, coordinates and other things every time i reload the file even in araes not modified. I get the warning that dimensions have become invalid but the columns have not moved. Any ideas what would be causing this problem.
Thanks,
Jeff
ARe you reloading from? Or are you actually re-linking? This sounds like you are linking.
To update linked models without closing the current project, you can unload and reload the linked models.
- Click Manage tab
Manage Project panel (Manage Links).
- In the Manage Links dialog, click the relevant tab.
- Select the linked model.
- To unload the selected model, click Unload. Click Yes to confirm.
- To reload the selected model, click Reload.
4 Posts No Rating |
I am reloading though Manage Links.
I don't know if we can help very much. I am assuming the link is Revit because you don't say. I have seen posts about dimension loss to CAD links but I have never seen any to Revit links.
In the view where you lose the dimesions are you possibly linking by view? If so then that is possibly your problem - I don't know for sure as I rarely ever link by view.
Problem with reloading groups - Bind link |
Thu, Apr 30, 2020 at 5:56:30 AM
How to delete a link |
Thu, Jun 12, 2014 at 3:59:57 PM
Reloading Linked Files - Lost Sheet Views |
Tue, Aug 23, 2011 at 8:52:01 AM
Reloading linked dwg |
Tue, Apr 29, 2008 at 8:08:23 AM
Link Families instead of load? |
Fri, May 4, 2007 at 6:12:06 PM
