8 Users Online (6 Members):
Forums >> Revit Building >> Technical Support >> 2013 revit new sheets not opening in correct discipline
How do I get new sheets to open properly in a specific discipline. they are all opening on a category at the below the discipline where I need them to be and I cannot figure out how to open them in the correct one or move the ones I've already created with the proper numbers.
Ha! Found it. Properties / category sort / *****
So endith the trick.
Sheets are NOT sorted in the view area. You can add a project parameter to sheets that you can use in your browser sort setup.
Linked Revit Model Sheets |
Fri, Apr 5, 2013 at 12:04:28 PM
Can't find Sub-Discipline in Properties |
Mon, Jan 27, 2014 at 5:24:22 AM
sheet index order with Linked models |
Fri, Mar 11, 2016 at 2:33:53 PM
Filtering placeholder sheets by discipline in a sheet list |
Thu, Jun 23, 2011 at 12:27:04 PM
Sub Discipline under Views? |
Fri, Apr 17, 2009 at 2:21:21 PM
