20 Users Online (18 Members):
Forums >> Revit Building >> Technical Support >> Room schedule with ceiling height
9 Posts No Rating |
Is there a way to display the ceiling height in the room schedule? I could add a parameter in the room schedule and edit it in manually, but I am trying to avoid any coordination problems this approach might create. The ceiling schedule does not have a room category, and the room schedule does not display the ceiling height as a parameter choice. Does anyone have any suggestions about how to link the two?
I am still new at this, and any suggestions are greatly appreciated.
-Marc
I've been wanting to do this too. Haven't found a way other than manually entering ceiling height.
6 Posts No Rating |
I put this problem up on another post then figured it out. Start by setting the upper limit higher then the ceiling. Place in a room schedule the area, and Volume make a calculated value Called  Clng Hght) or what ever you wish to call it , volume divided by the area Remeber to set the formula for length. This will give you the height of the Ceiling. Draw Back is only editible by moving the ceiling. cannot edit fromthe schedule itself. Hide the Columns you do not want to show in the schedule.
I made sure it was selected as "length", the formula is Volume/Area, used by "project settings" and selected my own, no luck. This is an existing schedule that I am adding the clng hgt column to. Can you think of what I am doing wrong?
Ceiling height in Room Schedule |
Sun, Apr 5, 2009 at 12:44:47 PM
Add Ceiling Height in Room Schedule |
Mon, Nov 19, 2012 at 9:38:54 AM
CEILING HEIGHT IN SCHEDULE |
Mon, Feb 18, 2019 at 6:34:48 PM
Can the room schedule have a column that automatically fills in ceiling height? |
Fri, Jul 13, 2007 at 11:53:52 AM
Room Schedule-Can I get the ceiling height to be automatically calculated? |
Mon, Sep 22, 2008 at 10:46:23 AM
