Forums >> Revit Building >> Technical Support >> Revit link unloaded v2014
Mon, Mar 17, 2014 at 3:30:40 PM | Revit link unloaded v2014
DanR
Somehow one of our linked models got Unloaded, when I reload it back in I will have to redo all of my customization as far as turning off grids, levels, etc. for that particular link in every single View Template and independent views.
Not sure how it happened, either user error or server migration issues, but besides berating the team for unloading/removing the link any ideas on how to get the visibility settings back, or prevent from happening in the future?
Thanks!
Mon, Mar 17, 2014 at 3:37:29 PM | Revit link unloaded v2014
This is a user error, even if the connection is broken, Revit maintains the link.
If you have a still with the link and there has not been much work done since the local was saved, you can create a central from that.  You can also possibly roll back your central to the point that still has the link.  Do this only after you create a new central with new name to fall back on.
Mon, Mar 17, 2014 at 3:38:36 PM | Revit link unloaded v2014
You can prevent this if you put the link in a workset that you checkout.
Mon, Mar 17, 2014 at 4:14:34 PM | Revit link unloaded v2014
DanR
I tend to agree with you that it is user error, and thank you for confirming that Revit will keep the link unless it is manually (stupidly) removed.
Too much has been done in the last few days to roll back to a previous file.
Good call on locking the worksets.
Importing Revit Drawings
Wed, Nov 22, 2006 at 4:17:40 PM
linked dwgs missing
Wed, Nov 27, 2013 at 7:49:03 AM
The Story of the Magic Invisible wall - a Revit Bug v2014
Fri, Jun 19, 2015 at 2:08:32 PM
Revit error messages
Wed, Jan 21, 2009 at 6:41:48 PM
Editable Text
Tue, Jun 10, 2008 at 5:09:57 PM
Page generation time: 1.9901
