Forums >> Revit Systems >> Technical Support >> modeling electrical clearance
Thu, Mar 13, 2014 at 12:45:38 PM | modeling electrical clearance
vinnygolfer
4.5 Stars: 4 Votes
hi to all. i'm using Revit 2014, and i'm building in the clearance for Electrical panels and other devices. i know how to build in the clearance, and get it to be mostly transparent. but the one thing that i have not been able to figure out is how to set the height of the clearance to automatically adjust to the room height. i would like to set up a parameter that will make the clearance go up to the bottom of the floor above, and automatically adjust if the floor changes. any ideas?
Try to learn at least one new thing every day
Thu, Mar 13, 2014 at 12:53:08 PM | modeling electrical clearance
Is this a reporting parameter?.... What is the reason for the height?
If the height is an instance set to a reference plane (strong reference), you might be able to lock that ref. to the bottom of the floor above after placement.  << But I'm not sure.....
Thu, Mar 13, 2014 at 1:04:32 PM | modeling electrical clearance
vinnygolfer
4.5 Stars: 4 Votes
even if it's a parameter that i can adjust after, i can just make it an instance. i was hoping that it would be automatic. since typically there are not a lot of equipment that needs the clearance all the way up, it's not a big deal. but if it can be done, i would like to know how to do it.
thank you again.
Electrical Clearance
Thu, Apr 3, 2014 at 10:07:24 AM
Cable Tray Clearance
Mon, Mar 24, 2014 at 10:44:48 AM
ADA door clearance
Thu, Jun 8, 2006 at 10:23:53 PM
Ceiling No-Fly/Clearance Zones
Mon, Sep 12, 2016 at 12:02:59 PM
Fri, Jun 14, 2019 at 5:48:11 PM
Page generation time: 0.0898
