Forums >> Revit Structure >> Technical Support >> Revit 14 issues
Thu, Mar 13, 2014 at 7:54:11 AM | Revit 14 issues
sblanck71
Good morning,
So yesterday my Revit 14 started freaking out. The toolbar ribbon didnt vanish, the entire top of revit vanished.  Everything on my screen was the plan view.  This would happen when I would cut a section to look at something and then switch back from section view to plan view.  Only thing I could do was use the task manager to close revit because nothing from the bottom of the toolbar ribbon to the top border was there anymore.
I have downloaded every hotfix, update and any other magic hocus pocus Autodesk has put out.
Any ideas?
Thu, Mar 13, 2014 at 8:05:16 AM | Revit 14 issues
So you have both updates installed - you don't say?  Make sure you look uder the ? dropdown - about....
If you have both updates and still have a problem then it may be your graphics card.  Turn off hardware acceleration if it is on and see what that does.  Make sure you have the latest driver installed for that card.  Is the card listed as working by autodesk?
Thu, Mar 13, 2014 at 8:14:14 AM | Revit 14 issues
sblanck71
No warnings under the graphics tab.
Hardware accelration isnt on.
Look under which drop down?
Thu, Mar 13, 2014 at 8:16:59 AM | Revit 14 issues
sblanck71
Yes all the updates are installed both of them
Thu, Mar 13, 2014 at 8:18:29 AM | Revit 14 issues
This one:
Thu, Mar 13, 2014 at 8:20:21 AM | Revit 14 issues
sblanck71
under the about tab:
20131024_2115(x64)
Update Release 2
Thu, Mar 13, 2014 at 8:26:38 AM | Revit 14 issues
Then it is either a corrupted installation or a hardware problem.
This was posted in another forum: "...Well were experience graphics issues with Revit 2014... We were having a problem with graphics, filled regions and then the ribbon started acting up and disappearing.... We downloaded and installed the .net framework 4.5 and the graphics issues seem to have been resolved now....."
Thu, Mar 13, 2014 at 8:34:04 AM | Revit 14 issues
sblanck71
I had the .net framework downloaded and installed.
I am doing a repair on it now.
Thu, Mar 13, 2014 at 8:57:37 AM | Revit 14 issues
sblanck71
still flipping out. I guess I will unisntall and reinstall
Thu, Mar 13, 2014 at 9:07:23 AM | Revit 14 issues
It would be advisable if you told us about your hardwarse.  It could be an incompatable card or out of date driver.  But i guess we are done.
Thu, Mar 13, 2014 at 9:27:33 AM | Revit 14 issues
sblanck71
Ok here are two screen captures of that stuff
Thu, Mar 13, 2014 at 9:33:17 AM | Revit 14 issues
You don't tell us what card....
....and you said "Hardware accelration isnt on."  but you image clearly says it is on....
Thu, Mar 13, 2014 at 9:37:23 AM | Revit 14 issues
#13
sblanck71
I just reinstalled and the default is for the accelleration is on.
Nvidia Quadro 2000
Thu, Mar 13, 2014 at 9:43:51 AM | Revit 14 issues
#14
sblanck71
Having issues uploading to Revit City
Mon, Jun 29, 2015 at 12:22:12 PM
Issues Upgrading Revit File
Fri, Jul 12, 2019 at 4:26:06 AM
Mirror issues, mouse selection issues
Wed, Dec 10, 2014 at 4:14:28 PM
CL Symbol Issues
Sun, Jun 19, 2011 at 11:17:43 AM
Rendering Issues!!!
Mon, Sep 29, 2014 at 8:52:19 AM
Page generation time: 1.2931
