Forums >> Revit Building >> Technical Support >> Revit revision table - alphabetical
Wed, Mar 12, 2014 at 9:13:07 PM | Revit revision table - alphabetical
revitico
I am using revit architecture 2014.
I am unable to modify my revision schedule from numerical to alphabetical.  It is supposed to be as simple as changing the field to alphabetical.
AFter I do that, the revit schedule still shows numbers on my sheets.  Is there a glitch?  Do others have a problem when switching to alphabetical?
Thanks
Thu, Mar 13, 2014 at 3:35:49 AM | Revit revision table - alphabetical
KimTaurus
KimTaurus Avatar
5 Stars: 3 Votes
Can you post an image of your settings? And one of the result?
Do you have a sequence with letters defined?
Revision table mystery
Thu, Jan 24, 2008 at 9:33:07 PM
12
Revision table
Fri, Sep 22, 2006 at 1:11:37 AM
Revision Tables
Fri, Jun 9, 2006 at 12:09:08 PM
i want the revision schedule only showing a specific revisions
Fri, Feb 10, 2012 at 11:54:41 AM
revision text color
Mon, Mar 25, 2019 at 1:17:50 PM
Page generation time: 2.1352
