Forums >> General Discussion >> Revit Project Management >> Fine, medium, course view option not available!
Mon, Mar 10, 2014 at 9:30:55 AM | Fine, medium, course view option not available!
dawingthedream
Hi all,
Revit 2013
Working on some interior elevations, and when I click on the bottom of the screen to select the detail grain for the view: fine, medium coarse, all the options are greyed out and I can't select between them. This is not the case with all interior elevations, only some.
This a software issue? Had some funky things going on before I installed the last service pack update (unable to close out of floorplate, roof, and profile sketch mode), and I worry this is a similar issue.
Let me know if anyone has solved this...
Thanks!!!
Mon, Mar 10, 2014 at 9:49:23 AM | Fine, medium, course view option not available!
You have a view template assigned that is controlling this.  In 2013 you don't have the same options as 2014.  You can edit the template and remove this control but this affects all views with this template.  You can remove the template from this view - bad option.  You can duplicate the template and create a new one with the settings you want.
Mon, Mar 10, 2014 at 9:52:32 AM | Fine, medium, course view option not available!
dawingthedream
right on. thanks!
Coarse, Medium, and Fine Settings
Wed, Dec 28, 2011 at 12:27:19 PM
Walls – Coarse, Medium and Fine or...
Thu, Oct 8, 2009 at 3:19:49 PM
Detail View Question - Cannot see columns in a medium or fine view
Thu, Aug 16, 2018 at 12:50:29 PM
11
sloping roof joists only displays on medium/fine
Tue, Mar 31, 2009 at 1:33:01 PM
Different colors in Coarse/Medium/Fine?
Mon, Sep 13, 2010 at 9:28:50 AM
Page generation time: 5.5428
