Forums >> Revit Building >> Technical Support >> PADS dont cut the TOPOGRAPHY
Mon, Mar 10, 2014 at 7:38:30 AM | PADS dont cut the TOPOGRAPHY
LOSpistos
Hey dudes!
so im havin an issue with my pads which are not cutting the topography?? To see the problem check the attached image.
thaaaaaaaaaaaaaaaaank uuuuuuuuuuuu
Luba
Mon, Mar 10, 2014 at 8:12:14 AM | PADS dont cut the TOPOGRAPHY
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
We need more information.  Are those actual building pads drawn fom the Massing&Site tab?  What version of Revit are you using? Do you have all of the updates installed?  Is everything on the correct phase if your using phasing?
Topography and pads trick
Mon, Jan 14, 2013 at 2:53:18 PM
CUT AND FILL - PADS WHICH DO NOT SHOW C&F VOLUME ON A SCHEDULE
Tue, Feb 13, 2018 at 4:37:06 AM
Revit Topography schedule - several issues!
Mon, Jul 14, 2014 at 8:59:00 AM
Pads mess up topography?
Sun, Oct 26, 2014 at 8:34:40 AM
problem pads and subregions , weird depression on topography
Sun, Mar 22, 2015 at 1:46:45 PM
Page generation time: 0.3872
