21 Users Online (19 Members):
Forums >> Revit Building >> Technical Support >> Facade detail help
I have searched both here and Autodesk forums.
I have a simple task that I did once. I want to create a simple shape that follows a path along my building and the shape would follow the path.
For instance, I want to create a 2x12 dryvit fascia about 12' above the f.f. On that fascia I want to have a 1x2 piece at the top and bottom of the fascia, creating a 'C' form. Last time I did this (over a year ago) I created the shape and I had pink lines that I connected to form the path that the object would be extruded along.
Any thoughts?
Thanks.
That's called a sweep.... Read about it in your HELP.
You can do a model in place, in a wall category for instance, and sweep along the path you pick in 3d.
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
Translucent polycarbonate facade |
Wed, Apr 2, 2014 at 4:06:07 PM
metal facade? |
Wed, Dec 21, 2005 at 9:37:10 AM
How to Create a facade |
Thu, Apr 18, 2013 at 7:25:50 AM
Existing Facade Creation |
Mon, Mar 25, 2013 at 7:49:07 AM
how to make use of revit for facade consultants |
Sun, Aug 28, 2011 at 11:29:19 PM
