Forums >> Community >> Newbies >> Family Symbolic lines Subcategory hidden lines uneven dash line
Sat, Mar 8, 2014 at 3:21:29 PM | Family Symbolic lines Subcategory hidden lines uneven dash line
Sitch
I have created a bath in a pluming family and had to use Sybolic lines to show in elevation but some of the line need to be dashed now so far thats ok, you can change the line type but Revit sees each line as seperate and creates an uneven dash line how or can do you fix this ?
Mon, Mar 10, 2014 at 7:57:49 AM | Family Symbolic lines Subcategory hidden lines uneven dash line
Im not sure what this means: ".... but Revit sees each line as seperate and creates an uneven dash line..."  Revit's dashed lines are one line - not seperate lines.
Edited on: Mon, Mar 10, 2014 at 7:58:13 AM
Symbolic Lines in Family - Display in Project
Fri, Jan 24, 2014 at 12:44:22 PM
Symbolic lines in elevation
Thu, Jan 10, 2008 at 7:12:53 PM
Symbolic Lines and Model Lines
Wed, Mar 22, 2006 at 12:52:17 PM
Symbolic Lines in Beam Families
Mon, Feb 24, 2014 at 3:54:58 PM
Line Styles Adjusting with Wall Hidden Lines?
Mon, Mar 12, 2018 at 12:58:29 PM
Page generation time: 2.0371
