Forums >> Revit Systems >> Technical Support >> victaulic elbows
Thu, Mar 6, 2014 at 10:02:09 AM | victaulic elbows
vinnygolfer
4.5 Stars: 4 Votes
hi all,
i have a project that specified Victaulic for the copper domestic piping. i loaded the files from Vic. and the elbows are giving me a fit. the elbow is the same file for 45 and 90 degrees. i loaded it in and for some reason it only wants to put a 45 on the pipe. i've included the files here. please let me know what i'm doing wrong. i have the .csv saved in the lookup tables. and the .rfa in the pipe fittings.
Try to learn at least one new thing every day
Thu, Mar 6, 2014 at 11:16:03 AM | victaulic elbows
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I don't use piping a whole lot but I could not get the 90 to work either, it may be a bad family.
Thu, Mar 6, 2014 at 11:45:06 AM | victaulic elbows
vinnygolfer
4.5 Stars: 4 Votes
for some reason when i imported the family and tried to use it i have problems. then i opened the family and loaded it into the project from the family editor, and now it works. just confusing.
Fri, Mar 7, 2014 at 9:55:17 AM | victaulic elbows
rschoch
I checked the elbow family you provided.  This family will only work in Revit 2013 and older.  If you are using Revit 2014 Victaulic has updated families that will work correctly in 2014.  Below is a link that shows how to fix the issue with the elbow if you like.  Connector 1 is missing the angle parameter being set.
http://static.victaulic.com/assets/uploads/cad_packages/Instructions/Revit_Project_Upgrade.pdf
Here is a link to the updated 2014 content.
http://www.victaulic.com/en/downloads/cad-files-software/autodesk-revit-mep/
Wed, Aug 13, 2014 at 11:02:00 AM | victaulic elbows
wildirish317
Thanks!  I had the same problem with a Mueller copper elbow.  Associating the connector with the angle parameter worked.
18" (450mm) storm piping & related fittings
Fri, Apr 17, 2009 at 5:16:01 PM
vic fittings
Tue, Dec 27, 2011 at 11:32:33 AM
How can I create calculated sloping ductwork, with elbows?
Sun, Feb 18, 2018 at 3:12:08 AM
Plumbing piping elbows
Tue, May 29, 2007 at 3:07:52 PM
Ductile Iron Flanged tee's and Flanged transition
Wed, Dec 31, 2008 at 1:07:34 PM
Page generation time: 0.4624
