Forums >> Revit Building >> Technical Support >> **URGENT HELP NEEDED** Graphics Issue With Color Fills
Wed, Mar 5, 2014 at 12:31:36 PM | **URGENT HELP NEEDED** Graphics Issue With Color Fills
archiphotovt
I have a new project we started about three weeks ago. I have to present the schematic plans tomorrow. I recently noticed a graphics issue for any view that has a color filled region or color scheme in an area plan. When you first open the view, all is well. As soon as you start zooming in, you get white artifacts from the model elements (doors, walls, etc.). Please see attached. Any thoughts on a solution?
HP Z420 Workstation
Windows 7 Professional
Intel Xeon CPU E5-1607
16 GM Ram
64 bit OS
129412_Graphics_Issue_01.JPG129412_Graphics_Issue_02.JPG129412_Graphics_Issue_03.JPG129412_Graphics_Issue_04.JPG
Wed, Mar 5, 2014 at 12:34:20 PM | **URGENT HELP NEEDED** Graphics Issue With Color Fills
archiphotovt
**Edit**
I have noticed that it only occurs where there are no floors or where the floors are turned off. Once you add the floors or turn the floors on, the issue goes away.
Thanks!
Wed, Mar 5, 2014 at 12:59:18 PM | **URGENT HELP NEEDED** Graphics Issue With Color Fills
Try turning off hardware acceleration ... under the Revit R dropdown - options - graphics.
You don't say what Revit and what updates.  You should be update 2 on 2014.
Wed, Mar 5, 2014 at 3:02:56 PM | **URGENT HELP NEEDED** Graphics Issue With Color Fills
archiphotovt
Good point. Revit 2014 but only update 1. My administrator is in the process of installing update 2. I don't have permission. I will reply back and let everyone know if that fixes it.
Thanks again.
Wed, Mar 5, 2014 at 3:03:42 PM | **URGENT HELP NEEDED** Graphics Issue With Color Fills
archiphotovt
BTW, hardware acceleration is already turned off.
Thanks!
Wed, Mar 5, 2014 at 4:28:23 PM | **URGENT HELP NEEDED** Graphics Issue With Color Fills
ishnabay23
4 Stars: 1 Votes
Update your graphics card (only if it hasn't been done already) and then turn the hardware acceleration back on.  I just had this issue last week and after I did this, it went away.
Mon, May 19, 2014 at 1:40:24 PM | **URGENT HELP NEEDED** Graphics Issue With Color Fills
archiphotovt
**UPDATE**
I am still experience this issue, after doing the following:
  • Confirming that my NVIDIA Quadro 600 graphics card has up to date drivers
  • Confirming that my Revit 2014 Revit Building has service pack 2 installed
  • Hardware acceleration is off
  • My .net Framework 4.5 is installed (per this: Revit 2014 Graphics Issue)
Running Windows 7 Professional and the above graphics card/Revit combination. Anti-Aliasing is off and Optimized View Navigation is on.
Anyone else out there have similar issues with a fix?
Thanks.
Edited on: Mon, May 19, 2014 at 2:07:36 PM
Mon, May 19, 2014 at 1:55:28 PM | **URGENT HELP NEEDED** Graphics Issue With Color Fills
After re-reading..... why not have your floors on?
Floors are room bounding elements and that may be causing some of your issues along with lower level walls that come up to the level of the view rather than being attached to the bottom of the floor.
Mon, May 19, 2014 at 2:09:09 PM | **URGENT HELP NEEDED** Graphics Issue With Color Fills
archiphotovt
I tried that. Folks who are using the presentation drawings don't want to see the slab edge at door openings. IF we leave the floors on, then we have to use the linework tool to hide all the boundaries of the floor slab...unless you know something I don't. I am all ears.
Thanks for the quick response.
Mon, May 19, 2014 at 2:18:48 PM | **URGENT HELP NEEDED** Graphics Issue With Color Fills
My floors are always edited to step out at the doors to the threshold.  But you can under VG / Floors - turn off slab edges.
Mon, May 19, 2014 at 2:50:40 PM | **URGENT HELP NEEDED** Graphics Issue With Color Fills
#11
archiphotovt
Thanks. I have noticed that check box for slab edges, but have never got it to do what I thought it should do. My understanding is that it only turns off any slab edge conditions that you've added using the Slab Edge tool under Floors. It doesn't actually turn off the boundary of a floor slab in plan view.
For some reason, I just turned off all three options under graphics, restarted Revit, then turned them all back on, and restarted Revit...it works. Whatever it was, it seems to have resolved itself, oddly enough.
Thanks again.
Mon, May 19, 2014 at 3:41:35 PM | **URGENT HELP NEEDED** Graphics Issue With Color Fills
#12
rbcameron2
rbcameron2 Avatar
4 Stars: 25 Votes
Ahh, the old "glitchy" lines in the background.  This was prevelent in 2013 too.
Let me guess, only one floorplan view is doing this?  Recreate the view when this happens again and delete the one that's glitching out.
Or update Revit and restart it.
I tend to find duplicate with detailing is faster though.  Winking
RB Cameron
3D Medical Equipment
Download Revit Healthcare Models Now
Download Other Revit + 3dsMax Models Here
Mon, May 19, 2014 at 6:44:25 PM | **URGENT HELP NEEDED** Graphics Issue With Color Fills
#13
dano3d
3.5 Stars: 3 Votes
Oh yeah... I've been getting the same "white lines". Something I've noticed is that they're more likely to appear if you have an "underlay" turned on in the problem plan view. Maybe this is your problem... worth toggling your "underlays" off to see if it does anything. I've also discovered that using the translucent override for filled regions also creates these lines sometimes. Found it useful to limit the use of transluscent filled regions unless it's really imprortant. Good luck.  Dan3d
Color fills
Thu, Aug 31, 2006 at 11:10:03 AM
Room Color Fills from one model to another linked model
Thu, Apr 8, 2010 at 10:40:57 AM
EXPORTING TO AUTOCAD- WITH NO COLOR FILLS
Sat, Mar 31, 2018 at 3:07:56 AM
Turn of Color Fills
Fri, May 19, 2006 at 2:31:06 AM
Shading Ductwork and Air Terminals on plan
Tue, Oct 19, 2010 at 2:39:20 PM
Page generation time: 4.3548
