Forums >> Revit Systems >> Technical Support >> Multiple Insertion Points in Generic Annotation Family
Tue, Mar 4, 2014 at 9:08:11 AM | Multiple Insertion Points in Generic Annotation Family
mrflanders
I am creating symbol families for some of our One Line Diagram symbols and am having trouble getting them to snap to where I need the snap points to be. All lines are set to be weak references. I am unable to create another reference plane assist me. I have attached a screen shot of a disconnect family. I need to be able to snap to the midpoints of each side of the square (circled in red) and am able to do so on the bottom and left side but the lines for the disconnect handle are throwing off the upper and right side. I am sure there is an easy solution I am overlooking, any suggestions?
Edited on: Tue, Mar 4, 2014 at 9:09:10 AM
Edited on: Tue, Mar 4, 2014 at 9:09:26 AM
Edited on: Tue, Mar 4, 2014 at 9:09:47 AM
Tue, Mar 4, 2014 at 9:33:49 AM | Multiple Insertion Points in Generic Annotation Family
You really should find the "Families guide" on the autodesk site.   From that you would read this:
Tue, Mar 4, 2014 at 9:42:54 AM | Multiple Insertion Points in Generic Annotation Family
mrflanders
I have tried to modify the reference of the square to be strong and it still does not allow me to snap to it.
Tue, Mar 4, 2014 at 9:50:15 AM | Multiple Insertion Points in Generic Annotation Family
The reference planes you have defined pass through the middle of the object - not the faces.
BTW - You can only have one insertion point.  But you can have multiple reference planes that you can dimension/snap to.
Tue, Mar 4, 2014 at 10:01:01 AM | Multiple Insertion Points in Generic Annotation Family
mrflanders
I understand that I can only have one insertion point (bad choice of words in the title) what I need is multiple snap points. In a generic annotation family I am not able to add additional reference planes to snap to.
Defining the reference plane through the center of the square is the only way I have been able to snap to the bottom and left midpoint of the square. It seems to be taking the overall footprint of the geometry and allowing me to snap to the endpoints of that footprint along the reference plane. I attached a screenshot to show what it is doing when I try to snap to the top.
Thanks for the help.
Revit Export Block Insertion Points
Fri, Oct 2, 2009 at 2:16:39 AM
Generic Annotation with Family Category based parameter
Mon, Sep 16, 2013 at 7:18:15 PM
Issue with annotation nested with generic model family
Wed, May 25, 2016 at 9:46:10 AM
Nest Generic Annotation in Detail Component
Wed, Mar 17, 2010 at 7:18:22 PM
Generic Annotation symbol
Mon, Dec 5, 2011 at 4:02:48 PM
Page generation time: 0.7234
