Forums >> Revit Building >> Technical Support >> property line try REVIT NOOB
Mon, Mar 3, 2014 at 7:13:32 PM | property line try REVIT NOOB
TRONYCA
So im trying to recreate a Pdf file(site plan) given to me in revit but cant get the arc to come out the way i want. can someone please explain or point me in the right direction on this. all youtube vid seem to cover importing images or autocad file but nothing much on making it from scratch in revit.
Tue, Mar 4, 2014 at 7:05:44 AM | property line try REVIT NOOB
What are you asking?
Print the Revit file to PDF.
Tue, Mar 4, 2014 at 7:09:07 AM | property line try REVIT NOOB
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Whats the problem?  you have 4 different options to create an arch that you want.  If your creating it just from a PDF your not going to get it 100% accurate anyway because your basically just trying to trace lines.
Tue, Mar 4, 2014 at 8:31:03 AM | property line try REVIT NOOB
TRONYCA
sorry, didnt read over my own writingm,i am the pdf file was given to me to recreate in revit im not trying to sketch it outwise it wont be the correct size. im trying to use the bearing info but the arc has 3 different info for lenght and im not sure how to input them.
Tue, Mar 4, 2014 at 8:43:09 AM | property line try REVIT NOOB
Now that is a much better question.
I'm not a surveyor but I think the radius, arc length, chord length and chord bearings are all listed.
ROUNDING VALUE ON PROPERTY LINE BEARING
Fri, Apr 8, 2016 at 1:13:37 PM
Property line
Tue, Oct 13, 2009 at 5:31:57 PM
Property line tables on sheet
Tue, Mar 14, 2017 at 1:29:57 PM
How to draw this property line?
Sat, Jan 23, 2016 at 4:48:18 PM
Property Boundary lines
Tue, May 30, 2006 at 10:45:31 PM
Page generation time: 1.7361
