Forums >> Revit Building >> Technical Support >> Trimming Walls to a slope
Thu, Feb 23, 2006 at 12:16:30 PM | Trimming Walls to a slope
daveg
Does anyone know how to trim walls to a specific slope where I cannot directly change the profile (ie on a curved wall) as I have imported geometry forming the roof and I need to trim the walls to the underside of the geometry. Cheers Smile
Thu, Feb 23, 2006 at 1:17:04 PM | RE: Trimming Walls to a slope
arccodex1
3 Stars: 1 Votes
You can create a Void in the shape of your imported geometry and "cut geometry" of the curved wall with a void.
Thu, Feb 23, 2006 at 6:14:07 PM | RE: Trimming Walls to a slope
daveg
Thanks for the help! Is that an in place massing object used to subtract from a wall object and if so is it possible to make a massing object just comprised of void "trimming" elements?
Fri, Feb 24, 2006 at 1:27:41 PM | RE: Trimming Walls to a slope
arccodex1
3 Stars: 1 Votes
No, that would be an in-place family with an extruded void not a massing object. No, but a family can be composed of just Voids cutting walls. Goto Modelling... Create... Generic Model Post edited on 2006-02-24 13:31:25
Fri, Feb 24, 2006 at 2:57:04 PM | RE: Trimming Walls to a slope
arccodex1
3 Stars: 1 Votes
You could also define a reference plane at the angle you want and attached the top of curving wall to the reference plane. Might be simpler.
connecting slope glaze roof to curtain walls
Sun, Jul 4, 2010 at 9:51:34 PM
Slopping Walls
Tue, Sep 27, 2005 at 12:07:30 PM
14
Roof's wont slope :(
Mon, Apr 2, 2007 at 5:34:05 PM
trimming walls to underside of stairs
Tue, Jun 13, 2006 at 1:20:21 PM
Having trouble trimming countertop
Fri, Apr 15, 2011 at 10:34:16 PM
Page generation time: 3.0193
