Forums >> Revit Systems >> Technical Support >> Import Rhino model into Revit
Sun, Mar 2, 2014 at 11:06:00 AM | Import Rhino model into Revit
annina
I have Rhino model of a whole building that looks fine and usable in Rhino but I can't import into Revit without it being an uneditable "blob". I have save it as sat-file and tried importing it directly, via family and via family as a mass. Have also tried via SketchUp but it is still a blob and I can't edit it. Then I have tried exploding the blob but it either erases everything or a part of the model depending how it was imported. Where is the problem? Somewhere in Rhino? I would very much appreciate your help. Thank you in advance.
Mon, Mar 3, 2014 at 7:42:36 AM | Import Rhino model into Revit
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Have you looked at any of the similar threads below? They may be helpful
Revit to Rhino
Thu, Feb 13, 2020 at 5:22:39 AM
Editing revit file in rhino.
Thu, Feb 13, 2020 at 5:19:48 AM
Rhino import "Instances"?
Wed, Apr 18, 2012 at 10:31:34 AM
Rhino to Revit
Thu, Oct 30, 2008 at 4:45:23 AM
URGENT HELP! Rhino polysurface to Revit Mass
Fri, Nov 20, 2015 at 11:27:53 PM
Page generation time: 4.2691
