Forums >> Revit Building >> Technical Support >> Automatic Ceiling error - less than 150mm
Sat, Mar 1, 2014 at 7:21:00 PM | Automatic Ceiling error - less than 150mm
chrischrischris
Hi.
I was wondering if someone could tell me if there is a know bug in Revit when creating a ceiling via "automatic ceiling" and there is a wall in the room that has a corner (or right angle kink) of less than 150mm (6").  If I increase the wall length to 154mm, then it works.
Regards, Chris
Mon, Mar 3, 2014 at 7:40:48 AM | Automatic Ceiling error - less than 150mm
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Are you saying the ceiling ignores the 6" wall?  I am not having a problem with it going around a 6" wall but I may not be understanding what you mean.  Do you have all of the updates installed for 2014?  I'm also assuming your using 2014.
Ceiling serious error
Thu, Oct 16, 2014 at 10:59:43 AM
Revit Ceiling Causing "Serious Error Has Occurred" Message
Thu, Aug 29, 2013 at 3:01:57 PM
Automatic Family
Tue, Sep 15, 2009 at 4:29:57 AM
Sloping Ceiling
Mon, May 25, 2009 at 2:35:31 AM
Walls will not connect to ceiling or roof
Mon, Mar 2, 2015 at 8:25:47 AM
Page generation time: 0.3755
