Forums >> Revit Building >> Technical Support >> Having two external finishes on the same wall
Sat, Mar 1, 2014 at 10:17:14 AM | Having two external finishes on the same wall
Geoge417
Is it possible to have a aluminium finish and a rendered finish at certain points of the wall without having to make two seperate walls. Any methods or suggestions would be greatly appreciated!
Mon, Mar 3, 2014 at 7:34:50 AM | Having two external finishes on the same wall
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Use the Split Face command then paint the areas of the wall you want a different finish
Complex External Wall Modeling - Urgent Help Needed
Wed, Dec 15, 2010 at 10:58:06 AM
Internal Wall Finishes
Tue, Mar 25, 2014 at 4:18:18 PM
Creating a wall finishes schedule, and coding wall finishes on elevations
Fri, Jun 1, 2012 at 4:06:32 PM
wall finishes by room
Tue, Apr 19, 2005 at 11:40:25 AM
Separating wall/ external wall junction
Wed, Nov 9, 2005 at 9:44:26 AM
Page generation time: 1.0045
