Forums >> Revit Building >> Technical Support >> Default value "Hide at scales..."
Fri, Feb 28, 2014 at 3:47:25 AM | Default value "Hide at scales..."
Nigolof
Is there a way to change the default scale value for view instance parameter "Hide at scales coarser than"?
Our template has 1:50 as default value for sections wich is very annoying and has to be changed manually every time scale is eg. 1:00 (very common). Elevations has default value 1:5000 and I find that much better.
Fri, Feb 28, 2014 at 7:21:12 AM | Default value "Hide at scales..."
You should be able to create a section in the template and reset the scale - delete the section and save.
Mon, Mar 3, 2014 at 5:41:57 AM | Default value "Hide at scales..."
Nigolof
Thanks for your answer. How do I "reset" the scale? I created a section in the template file, changed the "Hide at scales..."
to a value I want it to be but Revit does not remember last value when creating next section. "Hide scales at..." is still 1:50..
Mon, Mar 3, 2014 at 9:17:22 AM | Default value "Hide at scales..."
I'm sorry but it has been a few years since I messed with these so I forgot.
It appears that Revit will set the "Hide at scales coarser than" to the scale of the view when you create the section.  If your view scale is 1:100 when cut, it will be set to 1:100.  If it is 1:50, it will be 1:50.  If you want to change the scale of the view after placement, you can select all the sections at one time and reset this value.
Adding Costum Scale to the default list?
Tue, Jan 25, 2011 at 10:15:10 AM
"Default" Shared Parameters
Tue, Apr 27, 2010 at 2:55:57 PM
Elevations - Hide at Scales Courser Than
Mon, Mar 20, 2017 at 3:11:41 PM
Hide section markers at "Scale LESSER than"?
Thu, Sep 9, 2010 at 4:34:47 PM
Detail Callouts missing! Latest build didn't fix!
Thu, Oct 25, 2007 at 10:03:55 AM
Page generation time: 4.7014
