Forums >> Revit Building >> Technical Support >> I Need Sheet Number or View Name into Model element parameter
Thu, Feb 27, 2014 at 11:39:07 AM | I Need Sheet Number or View Name into Model element parameter
TimothyLiv
Hello,
I Need Sheet Number or View Name passed into Model element parameter that is visible within said Sheet Number or View Name.
Any help or direction is appreciated.
Thanks as always,
Timothy Livingston
Revit Architecture 2014
Thu, Feb 27, 2014 at 11:56:05 AM | I Need Sheet Number or View Name into Model element parameter
Sorry but I can't see any way to do this other than manually adding it.
Model elements can be visible in many different views so it just doesn't make sense.
Thu, Feb 27, 2014 at 1:25:21 PM | I Need Sheet Number or View Name into Model element parameter
TimothyLiv
Ha! That's exactlly our problem.
We have mulitple wall cladding panels on a project and the checkers are going crazy trying to track down
the individual panels from an Excel spreadsheet.  I would like to have a schedule for the panels visible on certain sheet.
I think I could be headed down an API or 3rd party programmer for this but wanted to check first.
Thanks again,
Timothy Livingston
Thu, Feb 27, 2014 at 1:35:49 PM | I Need Sheet Number or View Name into Model element parameter
If you build your schedule in Revit instead of excel, you can point to a panel in the schedule and see it in the model.
Numerate 'Sheet Number' parameter for match line family
Mon, Apr 28, 2014 at 10:17:51 AM
View Schedule with Sheet Number & Detail Number
Thu, Sep 1, 2016 at 12:07:37 AM
View List doesn't have parameter to show them in order of number on sheet?
Fri, Aug 26, 2016 at 2:48:10 PM
Index of details on a sheet
Wed, Aug 27, 2014 at 3:40:38 PM
Linking revision number to sheet number
Mon, Sep 20, 2010 at 1:50:30 PM
Page generation time: 1.2432
