Forums >> Community >> Newbies >> Formulas in Schedule
Thu, Feb 27, 2014 at 7:09:59 AM | Formulas in Schedule
HKicsak
We show two area values on our tenant plans- the actual square footage XXX and the lease value (XXX). In the schedule we are trying to calculate the difference between the two: actual-lease value.
Currently we have the lease value as a text parameter so we can enclose it in parentheses. This creates a problem however, because if I'm understanding formulas correctly you can't calculate with a text parameter.
Any ideas for a way we can calculate the difference and still display our areas the same way? All help is appreciated!
Using Revit2014, dragging the rest of the company with me from AutoCAD2008. When will the whining stop?
Thu, Feb 27, 2014 at 7:41:30 AM | Formulas in Schedule
You already understand you can't use text.... but you can have two columns either side of your number that have no header and show your ().  Or you can have another hidden column that is a number used in your formula.
Formulas for Schedules
Wed, Jul 22, 2009 at 3:31:28 PM
Understanding Formulas
Tue, Nov 16, 2010 at 1:36:05 PM
14
Calculating two Formulas on the same row in a Schedule
Fri, Dec 17, 2010 at 7:22:56 AM
formulas & schedule problem
Sun, Jan 13, 2008 at 2:24:09 PM
COUNT Parameter in formulas: a workaround
Thu, Apr 10, 2014 at 6:40:32 AM
Page generation time: 1.8011
