Forums >> Revit Structure >> Technical Support >> Tapered HSS beam - in need of
Tue, Feb 25, 2014 at 3:51:29 PM | Tapered HSS beam - in need of
sblake
Does anyone have a tapered HSS steel beam they would be willing to share?
Thanks!
Tue, Feb 25, 2014 at 4:00:14 PM | Tapered HSS beam - in need of
Please look at the similar threads below.
Tue, Feb 25, 2014 at 4:07:54 PM | Tapered HSS beam - in need of
sblake
I searched before I posted my request.  I saw tapered wide flange beams, but didn't see any tapered HSS beams.
Wed, Feb 26, 2014 at 7:07:49 AM | Tapered HSS beam - in need of
Edit the family that was posted as you need it.
Wed, Feb 26, 2014 at 7:19:02 AM | Tapered HSS beam - in need of
sblake
If I knew how to do that, I would. I am asking for one that has been done.
Wed, Feb 26, 2014 at 7:51:49 AM | Tapered HSS beam - in need of
I can pretty much guarantee that you will not find one already done.  Now you have an opportunity to expand your knowledge.  You can create this in place or edit the family in the first thread below.  It is a sinple swept blend.  Read about those in your HELP.
Wed, Feb 26, 2014 at 8:07:37 AM | Tapered HSS beam - in need of
sblake
Did you post threads? Because I don't see any in your post?
I would love to learn how to do this, and I will eventually. But, I have a deadline and I was trying to find a quick fix.
Wed, Feb 26, 2014 at 8:16:57 AM | Tapered HSS beam - in need of
Read my very first post!!!!
Wed, Feb 26, 2014 at 8:28:39 AM | WWHub
sblake
Quoting WWHub from 2014-02-25 16:00:14
This is all I see!
Wed, Feb 26, 2014 at 8:43:28 AM | Tapered HSS beam - in need of
That is a down arrow.  The very first similar thread has a family in it.  Edit the family if you want or create a new one.  Open it and look at how it's built.   I'm too far away to hold your hand too.
Wed, Feb 26, 2014 at 8:57:46 AM | Tapered HSS beam - in need of
sblake
And I'm sorry, I can't read between the lines and your "down arrows" to realize what that meant.
I simply asked for a tapered beam to download, not condescending remarks.
tapered beam
Wed, Apr 13, 2011 at 4:29:37 PM
Concrete tapered beam
Wed, Jul 3, 2013 at 12:05:46 PM
Tapered cantilevered beam with openings
Mon, Aug 14, 2006 at 5:06:16 AM
Tapered Beams
Thu, Nov 4, 2010 at 12:53:49 PM
Tapered beams
Thu, Mar 22, 2007 at 2:05:54 PM
Page generation time: 1.9704
