26 Users Online (24 Members):
Forums >> Revit Building >> Technical Support >> Linework tool and issue with wall common edges.
I am trying to turn some lines within a wall assembly (common edges) to invisible, when set to invisible using the linework tool, common edges display as a dashed grey line and they also print as a dashed grey line. See image attached, I am trying to hide a stud backing wall from passing through a box beam.
I have no overrides applied to wall common edges through v/g overrides.
Has anyone have an idea why this is happening?
There are two lines at every common line location and sometimes this process just doestn't seem to work.
Use edut cut profile with the edit line out of your view range.
Thanks WWHub, I hadn't thought about the cut profile tool for this process which works well for section/plan details. For wall sections I just thought to create a white line type to override common edges with using the linework tool and it seems to do the trick.
Cheers,
Nate
Change Common Edges Per Element |
Sun, Oct 22, 2017 at 4:46:54 PM
Linework tool issue |
Mon, Sep 26, 2011 at 3:20:44 PM
Revit 2014 - floor transparency and the linework tool |
Thu, Jan 9, 2014 at 10:38:52 AM
Linework Tool Issue |
Thu, Nov 20, 2014 at 7:18:16 AM
Linework Tool (LW) |
Thu, Mar 11, 2010 at 4:34:30 PM
