16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> Creating Custom Titleblock - Display Issues
0 Posts No Rating |
I am trying to recreate the company titleblock in Revit using lines and filled regions. Things went fairly well but I am having an issue with creating a correct display order when the titleblock is brought into a project. For instance, if I draw a filled region, say a square, and then draw another line around the perimeter with a heavier line to make this bold, the filled region border and this line do not read correctly on the imported titleblock. Or, trying to create a filled region and having white font stay in front of the filled region. How do you accomplish this?
Thanks!
Kevin
2013 Revit Build Suite
You haven't given us very much information. I suggest you read all the similar threads under titleblocks. And I suggest you do some testing on display order and draw order. Revit uses draw order alot.... which one was created first so experiment.
BTW - You do understand that filled regions can have different lign weights for any or all of their sketch lines....including invisible.
I would be careful with a "white" font. I don't know what you are trying to achieve. Sometimes logo's are best done elsewhere and inserted as image files.
For some reason you can't make white (RGB 255-255-255) text in Revit, it just appears black. At our company we use a very light grey (RGB 254-254-254) this will appear white when placed on a dark background.
Creating custom labels showing area in a titleblock. |
Wed, Aug 7, 2013 at 10:40:49 AM
display order |
Tue, Mar 27, 2007 at 11:48:55 AM
Help with some Titleblock issues... I just have a couple questions. |
Sat, Sep 13, 2008 at 12:41:41 PM
Titleblock Labels (Custom to each sheet) [ 1 2 ] |
Mon, Oct 5, 2015 at 2:46:21 PM
21
revisions display issue [ 1 2 ] |
Mon, Sep 15, 2014 at 3:23:27 PM
15
