14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> phasing
Do I need to duplicate each existing view seperately and change the phase settings to create working views for the next phase. Also should I change phase filter away from " None", which is default before creating new phases.
That is Revit LT 2014
If you are showing a new plan your phase will be set to new and phase filter will be set to show previous and new.. If you are showing a demolitio plan your phase will be set to new and your phase filter will be set to show previous and demo. These are 2 different views so you would need 2 different plans.
Phasing - Building Already Done but Dind't Set up Phasing |
Tue, Dec 15, 2009 at 7:40:42 AM
phasing |
Tue, Oct 23, 2012 at 8:20:21 AM
Phasing moved to Visibilty/Graphic |
Wed, Nov 18, 2009 at 4:11:56 PM
Wall and Instance phasing warning - Incorrectly Reporting? |
Thu, Oct 11, 2018 at 3:37:00 PM
PHASING |
Tue, May 20, 2008 at 1:57:25 PM
