Forums >> Revit Building >> Technical Support >> Light fixture does not host to ceiling
Sat, Feb 22, 2014 at 10:06:00 AM | Light fixture does not host to ceiling
pyziu
Guys,
There is an issue with putting face-hosted light fixture on the ceiling in Reflected Ceiling Plan in linked architectural model.
I would like to place that fixture on the ceiling, but I cannot do that. The fixture can be hosted to vertical elements i.e. walls, doors and even other fixture. In 3D view I can place the fixture in the ceiling. I opened architectural model and tried to put the fixture on the ceiling in that file and it worked. I assume the ceiling (in linked file) is not "recognized" as ceiling. The fixture family was downloaded from the manfuacturer's (Zumtobel) website.
I am using Revit MEP 2013.
Any ideas?
Regards,
Kamil
Mon, Feb 24, 2014 at 7:14:24 AM | Light fixture does not host to ceiling
You must own the host for hosted items.  Place a default ceiling in your model and use that.
Light Fixture - Recessed
Fri, Nov 13, 2009 at 9:14:57 AM
Light Fixture on Sloped Ceiling Displays incorrectly in section
Wed, Jun 1, 2016 at 6:43:11 PM
Opaque light fixture not emitting light
Wed, Dec 18, 2013 at 3:30:34 AM
light fixture height above floor
Mon, Nov 9, 2009 at 5:00:09 PM
ceiling plan, light fixture not showing
Sun, May 24, 2015 at 5:05:30 PM
Page generation time: 0.2000
