Forums >> Revit Building >> Technical Support >> Walls with 2" airs space on inside, whole wall is transparent form insed view?
Fri, Feb 21, 2014 at 10:09:12 AM | Walls with 2" airs space on inside, whole wall is transparent form inside view?
Stonehands
I created a wall with a 2" air space on the inside so my girst will show in the 3d views. My problem is the whole wall is transparent from the inside view.
How do I make the wall only transparent for the 2" air space. If i shrink the wall by removing the air space then the wall thickness is incorrect in plan and section.
Intent: To see only 2" of the 8" girt in the wall fron the inside in a 3d view. Marketing wants shaded views.
Edited on: Fri, Feb 21, 2014 at 10:09:38 AM
Fri, Feb 21, 2014 at 10:40:56 AM | Walls with 2" airs space on inside, whole wall is transparent form insed view?
Do it has two walls that are joined and turn off the inner wall in your 3D view.
Tue, Feb 25, 2014 at 10:57:28 AM | Walls with 2" airs space on inside, whole wall is transparent form insed view?
Stonehands
Do you mean add a second wall behind the first?
Wed, Mar 12, 2014 at 3:45:22 PM | Walls with 2" airs space on inside, whole wall is transparent form insed view?
chilie
Try making the air material transparent in the material editor itself. There is a "Transparency" option in the material editor assuming you have the correct material properties picked in the first place. Its on the "appearance" tab of that particular material.
Creating a special form - walls, roof and floors
Sun, Mar 29, 2009 at 8:42:58 AM
Floors and walls being transparent in 3D view
Thu, Nov 12, 2020 at 2:52:52 PM
11
Non Transparent Curtain walls in 3D View?????????
Fri, Sep 11, 2009 at 1:48:58 AM
aligning two curtain walls/panels in a Blob-like form
Wed, Jan 22, 2014 at 1:39:53 AM
Wall with Trusses become transparent?
Thu, May 1, 2014 at 7:45:05 PM
Page generation time: 1.4127
