11 Users Online (9 Members):
Forums >> Revit Structure >> Technical Support >> Cuts on reference planes dropping off when elements are moved
12 Posts No Rating |
When I 'move' an element that has its end(s) cut on a refenence plane they loose thier ascociation with the plane and the cuts drop off however when I 'align' or 'drag' an element the cuts stay on the reference planes. I am the only one in this office this happens to and I cannot work out why it happens, it is very frustrating.
Does anyone know how to fix this? Thanks.
Are you moving with disjoin checked?
no disjoin is not checked, have also tried turning constrain on and off with no luck
-Bump
Any Ideas?
I can pretty much understand why move doesn't work because the association to the cutting plane is lost. What I have trouble understanding even yet is what is the logic on dragging buttons. On some objects, the object moves. On others, the object changes length. I believe this depends on which end was the creation start but I have not tested by theory.
Sorry, I can't give you more help.
Seems to work on everyone elses PC in the office, Kind of annoying having to recut an element every time you move it yet if you drag or align the element it keeps its cuts.
Hidden Reference Planes disappeared |
Fri, Jun 30, 2017 at 11:50:56 AM
Listing the Abilities of Reference Planes |
Sun, Sep 9, 2012 at 9:24:07 PM
reference planes |
Wed, May 24, 2006 at 10:19:12 AM
Detail Lines and Reference Planes |
Tue, Sep 20, 2016 at 2:37:46 PM
Reference Plane Dimension |
Sat, Aug 20, 2005 at 7:33:46 PM
