Forums >> Revit Building >> Technical Support >> maxwell installation error!!!!! sos
Thu, Feb 20, 2014 at 4:19:06 PM | maxwell installation error!!!!! sos
Chlo0oex
I downloaded the maxwell plugin for revit 2013, but when i open my file in revit a message comes up saying that maxwell is missing a file called ''maxwell.dll'' . When i went to check the location that it mentioned the file was there... any help?
Fri, Feb 21, 2014 at 7:45:33 AM | maxwell installation error!!!!! sos
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Try reinstalling the plug in, or try contacting Maxwell.
Fri, Feb 21, 2014 at 8:25:43 AM | maxwell installation error!!!!! sos
Chlo0oex
i did reinstall several times but i still get the same problem! i will try contacting maxwell! thank you for your reply!
Fri, Feb 21, 2014 at 8:29:32 AM | maxwell installation error!!!!! sos
Chlo0oex
i did actually contact them..completely forgot..but they send an email saying that they answer personally one mail accounts so that will take a while.
Fri, Feb 21, 2014 at 8:36:07 AM | maxwell installation error!!!!! sos
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Is there a contact number you could call instead of email?  I would assume this is a Maxwell issue and not a Revit issue.
Thu, Jul 3, 2014 at 1:59:12 AM | maxwell installation error!!!!! sos
world313
I downloaded the maxwell plugin for revit 2014.
Wh
Thu, Jul 3, 2014 at 2:01:22 AM | maxwell installation error!!!!! sos
world313
I downloaded the maxwell plugin for revit 2014. but when i open my file in revit a message comes up saying that maxwell
Thu, Jul 3, 2014 at 2:02:52 AM | maxwell installation error!!!!! sos
world313
can i help you??????????????????????????????
Thu, Jul 3, 2014 at 7:43:45 AM | maxwell installation error!!!!! sos
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Do as the error says and contact Maxwell
Wed, Jul 9, 2014 at 1:45:38 AM | maxwell installation error!!!!! sos
world313
Yes, a warning appears., You do mate. If you help me?
Wed, Jul 9, 2014 at 1:57:11 AM | maxwell installation error!!!!! sos
#11
world313
If you give your email or a link from Maxwell to share my issue with them. Thanks
Wed, Jul 9, 2014 at 5:35:51 AM | maxwell installation error!!!!! sos
#12
4 Stars: 205 Votes
Here: http://www.maxwellrender.com/contact
Edited on: Wed, Jul 9, 2014 at 5:36:33 AM
Wed, Jul 9, 2014 at 8:37:52 AM | maxwell installation error!!!!! sos
#13
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
World313- You have posted this question a bunch of times in multiple threads.  You will need to contac Maxwell to get an answer.  I deleted your other posts
Wed, Aug 20, 2014 at 3:56:23 PM | maxwell installation error!!!!! sos
#14
agentasg
This is because wrong Maxwell installer. Try to add slash in end of installing path.
Before:
C:/your_path_to_revit
After:
C:/your_path_to_revit/
REVIT MEP 2012: Installation problem-Error 2343.Specified path is empty.
Fri, Apr 29, 2011 at 7:30:51 PM
installation error
Sat, Aug 30, 2008 at 9:35:55 AM
Maxwell Render for Revit
Thu, Aug 31, 2006 at 6:05:54 PM
Maxwell render plugin for Revit
Wed, Apr 20, 2016 at 12:15:53 PM
MAXWELL RENDER SUPPORT PLUGIN!!
Fri, Jun 29, 2007 at 1:32:52 PM
Page generation time: 1.0489
