Forums >> Revit Building >> Technical Support >> What is the blue square in massing?
Thu, Feb 20, 2014 at 4:14:20 PM | What is the blue square in massing?
tonyphillips
When I create an in-place mass and select a draw tool, I get a blue square appear in the project area. It's not a crop region. Any ideas what it is? It dissapears as soon as I draw a profile for a mass?
Cheers,
Tony
Fri, Feb 21, 2014 at 7:44:07 AM | What is the blue square in massing?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
What version of Revit are you using.  Can you attach a screen capture of it, I don't get any type of box when I try to create an in-place mass.
Fri, Feb 21, 2014 at 8:19:45 AM | What is the blue square in massing?
4 Stars: 205 Votes
Are you talking the "Workplane"?
Fri, Feb 21, 2014 at 8:10:20 PM | What is the blue square in massing?
tonyphillips
Yes I think you are right. The workplane. Thanks Winking
Teafoe5. You many get it if you are in a floorplan view?
Cheers,
Mon, Feb 24, 2014 at 7:22:12 AM | What is the blue square in massing?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
When you are in your mass you will see that under the Create Tab>Work Plane there is a Show button.  Just click on it to turn it on or off.
Blue items show up red
Mon, Dec 9, 2013 at 4:14:26 PM
Rentable Square Feet Calculation
Wed, Jan 28, 2015 at 9:29:10 AM
Looking for quick easy square footage calculator
Mon, May 19, 2014 at 10:49:34 AM
why my massing can't not be a solid?
Fri, Feb 11, 2011 at 8:26:42 PM
Square Yards calculations
Mon, Mar 19, 2012 at 3:00:43 PM
Page generation time: 0.0915
