Forums >> Revit Building >> Technical Support >> Revit 2014 Vertical Bracing Problems
Thu, Feb 20, 2014 at 10:26:00 AM | Revit 2014 Vertical Bracing Problems
mogorzaly
Has anyone had problems modeling in vertical bracing in Revit?  I am not new to Revit or to adding vertical bracing, but I am trying to add vertical bracing in a framing elevation and the brace is being offsetted vertically by about 60-70 feet.  I get into the framing elevation, pick vertical bracing tool, and then snap to one column and then snap to another column and then the brace is placed way above or below. I can't understand why I did this the exact same way yesterday and now today it will not work.  Any help would be very much appreciated. Thanks in advance.
Vertical bracing symbolic line ???
Tue, Jun 4, 2013 at 7:33:50 AM
Vertical and horizontal bracing connections
Mon, Jun 24, 2013 at 7:18:38 AM
Vertical bracing line
Sun, Jun 2, 2013 at 2:17:03 AM
vertical bracing problem / bug
Wed, Jan 18, 2012 at 3:13:12 AM
Vertical bracing in plan question
Wed, Sep 26, 2012 at 1:01:35 AM
Page generation time: 1.8448
