Forums >> Revit Building >> Technical Support >> Random Walls not printing the Pattern
Thu, Feb 20, 2014 at 9:00:55 AM | Random Walls not printing the Pattern
cleslie13
In the attached clip, you can see that some of the stone walls are not showing.  The bottom of one of the columns and the left side of the bottom of the tower.  I'm very new at Revit, but can't figure this out.  It is Random.  The one column does show on that side, but the other doesn't.  Same problem with the house attached.  It shows up on the sheet, but when I go to print or even preview the print, it does not show up.
Help
Carol
Thu, Feb 20, 2014 at 9:21:34 AM | Random Walls not printing the Pattern
As of about 2012, preview print does not show everything.  I don't know what they messed up but that is a continuing problem.
Hatch patterns at oblique angles may not show up in your screen views because they become too intense and a solid.
Random stone walls
Thu, Jun 26, 2008 at 5:04:39 PM
Revit 2010 printing random lines
Mon, Jan 4, 2010 at 10:51:09 AM
Random LVT floor pattern
Wed, Sep 8, 2021 at 12:26:39 PM
brick pattern not printing in elevation
Thu, Jun 25, 2009 at 10:07:55 AM
Room Color Fill Not Printing, Random Circle is
Wed, May 17, 2006 at 6:20:12 AM
Page generation time: 0.4060
