17 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> Schedule is Empty?
7 Posts No Rating |
Hello,
I am finished modeling my building and when I go into my room finish schedule, the cells are empty, even though finishes are specified for walls, floors, and ceilings throughout the buildling. It isn't even reading the ceiling height? The door schedule is also empty, even though the finishes are specified in the properties.
Thank you!
7 Posts No Rating |
I am using Revit 2014
Sorry but you have misunderstood some things.
- Room schedules will not automatically read properties of anything except the room itself. You can add a schedule parameter to rooms and fill that in.
- If your door families have the proper parameters assigned to them, then your door schedule should read those.
You need to spend some time with tutorials on scheduling and parameters.
7 Posts No Rating |
Thank for your reply. Do you know if there is a way to change one of the finishes that is put in the schedule and it will change the rest that are the same? Like if I wanted to change all of the "Ceiling Tiles" to "Acoustical Ceiling Tiles"?
Sort you schedule by that field and don't show all instances. Now they will be one item that you change.
Learn to create working schedules that you can change all the time as needed.
Revision schedule showing revision sequence numbers with empty descriptions |
Thu, Feb 28, 2013 at 3:46:03 PM
R 2020 - Empty CW Panel attach to roof ? |
Mon, Oct 28, 2019 at 10:29:48 AM
Curtain wall - empty panel issue |
Mon, Mar 25, 2013 at 2:34:28 PM
13
Empty layers in DWG-file. |
Mon, May 13, 2013 at 3:59:04 AM
Panel Schedules are empty |
Tue, Apr 2, 2013 at 11:35:38 AM
