11 Users Online (11 Members):
Forums >> Community >> Newbies >> View Template Difficulty
2 Posts No Rating |
Good Morning!
I have two separate area plans, one of which has everything showing up correctly (plan A). To save time I created a view template from plan A and applied it to the plan B. Now when I go to annotate plan B- wall tags in particular- I get the following error message:
None of the created elements are visible in Area Plan (Rentable): WET SEAL- K COPY View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings.
I don't understand- the visibility should be the same as plan A, since a view template is applied, correct? The wall tags are showing in plan A but I cannot get them to work in plan B.
Any help is appreciated!
Using Revit2014, dragging the rest of the company with me from AutoCAD2008. When will the whining stop? |
This is a process error somewhere.
- Did you check VG for this view first? OBVIOUS FIRST PROCESS BEFORE ASKING HERE
- View templates can be created that only control portions of the view. Check what the template controls.
2 Posts No Rating |
Yes, as far as I can tell all of the VG match plan B to plan A. (To guarantee this I created the view template from plan A and applied it to plan B. I was under the impression it would then be exactly the same- I haven't made any changes to that view template.) And all features are included in the view template- is this what you mean by what it can control?
Maybe I'm misunderstanding the function of view templates.
No, it sounds like you understand the view template use. BUT - You didn't check the VG settings. What do you need to tag a wall?
- You need a wall. Are walls on and are they in your view? NOT an underlay!
- Under VG annotations, wall tags have to be on - are they?
- Does your view cut plane actually cut the wall? If the wall is below the view cut, the wall will not tag.
- Do you have any filters applied?
- Are the walls individually hidden in view?
view template applied to each placed view |
Thu, Jul 2, 2015 at 2:36:37 PM
Which View Template am i working with? |
Tue, May 10, 2016 at 12:31:40 PM
Revit 2015 View Template Linked Vew resets to None Hiccup |
Tue, Jun 28, 2016 at 4:50:06 PM
View Template with automatically annotated families |
Mon, Oct 27, 2014 at 3:50:30 PM
Workset VG in View Template |
Mon, Nov 24, 2008 at 8:27:08 PM
