9 Users Online (7 Members):
Forums >> Revit Building >> Technical Support >> Scale issues
5 Posts No Rating |
Hi,
I have attached an example of a plan i have at 1:100 and what happens when I change the scale to 1:500.
As you can see the grids and text go huge when the scale is changed to 1:500, does anyone know what settings i need to change to amned this?
thanks
This is the size it needs to be in order to print actually 3/32", 1/8" etc. If you want smaller text you will need to change your text from (for example) 1/8" to 1/16"
5 Posts No Rating |
Hi,
But what about the grid bubbles and the room tags?
thanks
These are ALL annotations and follow the same rules. If they didn't change with the view scale you wouldn't be able to read them when they print. If you NEED them smaller you will need to edit the family
5 Posts No Rating |
Hi,
So what about if I want one drawing sheet with a plan at 1:500 and another drawing sheet with a plan at 1:200?
Will I have create two separate plans with different grid and text sizes?
thanks
Most individuals recognize that reading the number is what is important. On very small scales we usually turn off all but the first and last column numbers.... or maybe every other one or similar approach but the bubble size stays the same in all views.
PAT file scale issues |
Thu, Mar 20, 2008 at 7:03:28 AM
Scale Issues in Titleblock |
Thu, May 2, 2013 at 5:01:38 AM
3ds Max .fbx and UVW issues |
Wed, Sep 3, 2008 at 11:02:09 AM
PRINTING ISSUES. When printing to CutePDF my drawings won't come out to scale. |
Tue, Sep 6, 2011 at 7:51:06 AM
Scale bar on sheet onto to display at certain scale |
Wed, May 22, 2013 at 12:15:22 AM
