Forums >> Revit Building >> Technical Support >> curtain wall grids - deleting them
Wed, Feb 22, 2006 at 8:11:02 PM | curtain wall grids - deleting them
jeffericson
All right - I'm sure I'm missing something extremely obvious. I've got all these beautiful curtain grids, and I lowered the ceiling height of a level above and now have too many horizontal grid lines. I select it, hit delete, nothing. I hit the add/delete segments, and delete until I get to the last one, then get the error that says you have to have at least one! What am I missing? Just go away, silly grid line! Thanks
Wed, Feb 22, 2006 at 11:12:52 PM | RE: curtain wall grids - deleting them
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
is it a curtain wall system? When you select it do you see picture of a pin? This means its a system and the grid layout is controlled by rule. Either change the rule, or select the grid, then click the pin to unpin it, then delete it. HTH.
Thu, Oct 9, 2008 at 4:54:26 PM | curtain wall grids - deleting them
Warchitect
4 Stars: 5 Votes
So I have had the same problem.
I did in fact unpin it, but it still wont let itself be deleted. you must set the rule to none first, then you can unpin and kill it. :-P
Wed, Mar 18, 2009 at 3:33:07 PM | curtain wall grids - deleting them
elbrown
What rule do I need to change??  I have the same problem...  please help. thank you for your time and patience...
eric
Wed, Mar 18, 2009 at 3:52:33 PM | curtain wall grids - deleting them
When you define a curtain wall type, you can control several settings ... mullion spacings vertically, horizontally and the mullions vertical / horizontal - in other words automatic or at least semi-automatic.  .... or you can not have anything set and add everything where you want it.
When you use the automatic settings, you will find that  changes you make are often lost.  That's because Revit tries to remake the curtain wall as it is defined.  If you need to change this wall by deleting grids, you will need to change the property of the grid and disassociate i.
I have a curtain wall type that has no pre-sets.  After I place an automatic curtain wall, I change its type to the non-automatic (and answer no to any deletions revit wants to do).  This will enable you to then change spacings, add curtain wall doors ...etc.
Wed, Mar 18, 2009 at 4:09:30 PM | curtain wall grids - deleting them
elbrown
thank you.  i now have a small grasp on curtain walls.  do you know where there is any more information on curtain walls and doors?  i am drawing up a single story office complex and it has store front type windows and doors.  it is mostly curtain walls, however i am not too familier with both of them.  thank you for your help again and also for pointing me in the right direction for info on the curtain walls and doors..
eric
Thu, Mar 19, 2009 at 8:06:39 AM | curtain wall grids - deleting them
Revit does not make any distiction between curtain walls or storefront, they are both built the same way.
A good place to start is to read your HELP on curtain walls, it covers very well all aspects of using curtain walls.
Random Diagonal Curtain Grids in a Curtain Wall
Wed, Jul 6, 2011 at 6:57:03 AM
non parallel curtain wall grids
Sat, Apr 28, 2007 at 12:54:05 AM
Slanted curtain wall help! (pic attached)
Wed, Oct 22, 2014 at 6:02:39 PM
revealing hidden curtain grid
Mon, Sep 8, 2008 at 3:55:02 PM
Revit sloped glazing & angled curtain grids problem
Thu, Feb 25, 2016 at 11:33:26 PM
11
Page generation time: 2.3170
