Forums >> Revit Building >> Technical Support >> Scaling Viewports
Tue, Feb 18, 2014 at 7:46:11 AM | Scaling Viewports
danher1974
Hi,
I have an A1 drawing sheet which I have just dropped my Ground Floor Plan into. The GF Plan was drawn at a scale of 1:100, but needs to be at a scale of 1:500 on the drawing sheet. When I change the viewport scale to 1:500, all the Grids and text stay at a scale of 1:100 (huge). I s there a way to bring the scale of he grids and text in line with the viewport scale?
Thanks
Tue, Feb 18, 2014 at 8:09:52 AM | Scaling Viewports
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
There really is no viewport in Revit. You change the scale of the actual view.  If in your view you changed your scale from 1:100 to 1:500 the text will automatically change so you are doing something incorrect.
Tue, Feb 18, 2014 at 8:14:53 AM | Scaling Viewports
danher1974
Hi,
Any idea what I am doing wrong?  I presume there is some setting I need to adjust?
Thanks
Tue, Feb 18, 2014 at 8:32:35 AM | Scaling Viewports
Thread Post Kudo! #4
TKennedy
4 Stars: 8 Votes
Grid bubbles and text are annotation and have no scale. They stay the same size on the sheet regardless of the scale of the view, so a 1/2" grid bubble will always print at 1/2".
Edit Visibility Graphics in multiple viewports?
Mon, Nov 28, 2011 at 1:37:05 PM
Viewports orginizing on sheet
Mon, Apr 18, 2016 at 10:45:14 AM
Room Plans, Non Rectangular viewports from Revit 2014 and Python Shell
Thu, May 23, 2013 at 2:28:19 PM
many viewports
Mon, Aug 24, 2009 at 9:17:12 AM
Scaling Family or component- similar to scaling jpeg
Mon, May 12, 2014 at 2:44:09 PM
Page generation time: 1.5369
