Forums >> Revit Building >> Technical Support >> Lighting tags move when "emergency option turned on/off
Wed, Feb 12, 2014 at 3:50:02 PM | Lighting tags move when "emergency option turned on/off
wick01702
I am building a electrical library using Revit 2013. I noticed this problem while creating lighting fixtures with an emergency filled region associated with a yes/no parameter. Once the fixture is placed within my project and its tagged with a "Type Mark" tag. If I select or deselect the instance parameter for emergency hatch, the type mark tag moves to a different location than where I had placed it. I cannot figure out what is causing the lighting fixture to act this way. I have created different types of fixtures as well as hosted and nonhosted. Not all of my families are behaving this way though. I have also noticed it on other families that I created with "clearances" yes/no parameters.
Thu, Feb 13, 2014 at 7:22:03 AM | Lighting tags move when "emergency option turned on/off
Tags attach typically to the center of a family and that may be changing when you switch this.
Am I dreaming or did I read something about being able to set the tag location now in the family 2014?
Mon, Apr 28, 2014 at 11:10:05 AM | Lighting tags move when "emergency option turned on/off
Madge
WWHub - any news on setting the tag location in 2014?
Mon, Apr 28, 2014 at 6:05:17 PM | Lighting tags move when "emergency option turned on/off
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I don't think I've seen a tag move by just changing the family type (which basically turns a fill pattern on).
However if the emergency fill pattern is a 'nested' family with a different base point from the main family it may just jump based on what WW states. ie: Keep the two base point the same. Basepoint is defined at the intersection of two reference planes that 'define origin' as properties.
Edited on: Mon, Apr 28, 2014 at 6:07:00 PM
Help. I forgot how I "turned off" the room tags.
Tue, Oct 8, 2013 at 7:18:18 AM
11
tags tags tags
Tue, Mar 20, 2012 at 12:10:23 PM
Looking for Emergency Vehicles and plants
Sat, May 16, 2009 at 3:09:23 PM
Tags linked in more than one view
Fri, Feb 27, 2009 at 6:21:47 AM
revit 2012 - display option background disappeared and turned black
Mon, Jun 25, 2012 at 4:48:13 PM
Page generation time: 0.9165
