Forums >> General Discussion >> Revit Project Management >> Site Plan - Topo
Wed, Feb 12, 2014 at 10:28:48 AM | Site Plan - Topo
stevedcnr
I am creating a topo by Pick Points that I can't seem to do sharp radius for.  I am wondering what setting(s) control this function? If I do simple straight contours there is no problem. Attached is the base drawing for picking these points. If you look at that drawing when I start picking points for 1152 at the point when I get to the sharp radius point on that line the red contour line goes off and system seems to reinterpret the contours.
Wed, Feb 12, 2014 at 10:38:48 AM | Site Plan - Topo
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Your image doesn't tell us much.  Most likely you will just need to add even more points to get the desired radius, if Revit is interpreting your points wrong you will need to add more points elsewhere to "force" the contours to where you need them.
Wed, Feb 12, 2014 at 10:55:40 AM | Site Plan - Topo
Please read my posts here: http://www.revitcity.com/forums.php?action=viewthread&thread_id=31567
Contours are just an approximation.   You can also add point elevation tags to are not on the contour line if something has to be controlled.
Thu, Feb 13, 2014 at 5:50:25 AM | Site Plan - Topo
markrentboi
I HAVE THE SAME PROBLEM CONTROLLING THE TRIANGULATION OF MY TOPO. I ADDED POINTS ALREADY, IN THE FACT TOO MUCH! :D HOW I CAN I GO ABOUT THIS?
Thu, Feb 13, 2014 at 7:29:53 AM | Site Plan - Topo
The thought that topo lines have to be in a particular location is just plain wrong!  Users that demand this don't understand what these lines represent.
level elevation doesn't match elev point in topo / site plan
Wed, Dec 18, 2013 at 4:05:00 AM
13
RAC 2009 - Topo Site Work
Fri, May 9, 2008 at 3:08:34 PM
lines on topo surface
Wed, Aug 3, 2011 at 8:37:21 AM
importing topos for a Site Plan
Sat, May 28, 2005 at 10:20:13 PM
Wall on Topo Site
Wed, May 28, 2008 at 5:00:38 AM
Page generation time: 1.4375
