Forums >> Revit Structure >> Technical Support >> Shared Parameters File is not a valid...
Wed, Feb 12, 2014 at 9:14:21 AM | Shared Parameters File is not a valid...
LOSpistos
Hi to all,
everytime i click on the Shared parameters below the Manage Bar a warning show up telling me that the file: C:/Programdate/autodesk..... could not be read or is not valid shared parameter file...
Can somebody help me where can i locate my previous shared parameters link?????
THAAANK UU A LOT
Luba
Wed, Feb 12, 2014 at 9:24:42 AM | Shared Parameters File is not a valid...
We would not have a clue as to where your shared parameter file is.
Nor would we know if it is truely a shared parameter file.  You must create these through Revit or copy one that was created correctly.
So .... you need to tell us what your process was.   Look through your files (DOS - not Revit) to see if you can find it.
Wed, Feb 12, 2014 at 9:31:26 AM | Shared Parameters File is not a valid...
LOSpistos
OMG ur reply was so quick..yeeah u were right with the DOS ...i just found it.
thank you very much Smile
Shared Parameters Text File? Has anyone used this?
Tue, Jun 14, 2011 at 10:11:56 AM
Shared Parameters
Thu, Feb 9, 2006 at 1:41:58 PM
How to permanently purge Shared Parameters easily(without API access)?
Mon, Nov 23, 2020 at 1:00:39 PM
Shared Parameters Workflow
Tue, Sep 21, 2010 at 7:53:53 AM
Shared or Project Parameters?
Tue, Jan 19, 2010 at 7:01:11 PM
Page generation time: 2.7912
