Forums >> Community >> Newbies >> Curtain wall with external wall join
Wed, Feb 12, 2014 at 8:47:25 AM | Curtain wall with external wall join
broigutt
Im having problems over and over again with curtain walls joining into external and internall walls
See pic
any suggestions?
Wed, Feb 12, 2014 at 9:30:31 AM | Curtain wall with external wall join
Click on the CW and turn off wall join for that end of the wall.
Wed, Feb 12, 2014 at 11:21:28 AM | Curtain wall with external wall join
broigutt
Thanks for the reply
How is that done? I cant see the command
are you refering to the wall join tool?
Wed, Feb 12, 2014 at 11:35:06 AM | Curtain wall with external wall join
If you click on any wall, you will see a blue dot at the end.  Right click on that and you can turn off wall joins.
Wed, Feb 12, 2014 at 11:47:48 AM | Curtain wall with external wall join
broigutt
Brilliant, worked like a charm
Thanks a bunch
Separating wall/ external wall junction
Wed, Nov 9, 2005 at 9:44:26 AM
Curtain wall and mullion issues
Wed, Sep 5, 2007 at 7:38:14 PM
Wall Join - How to Turn Off this option
Thu, May 22, 2014 at 11:37:09 AM
External Glass Curtain Panel Problem
Tue, Aug 12, 2014 at 8:05:34 AM
Dividing an external wall into different parts per floor
Fri, May 12, 2017 at 3:46:57 PM
Page generation time: 1.0146
